1 - 20 of 41 Posts
i looked all over the place and found that according to Triumph, the proper iridium plugs for the 2002 Triumph Sprint ST 955i was the DPR8EIX 9. but after spending the money on them, getting them shipped, they turned out to be the wrong ones. I cannot find anywhere how to get the proper NGK Iridium plugs because everything points back to this wrong number. I reverted back to the regular NGK plug.
Mine are Unobtanium. Only found on passing asteroids. Created by Nymphs.
What plug number should they be if not DPR8EIX 9?
Who is it that says these are incorrect?
If it's any consolation, iridium plugs cost more but do absolutely nothing for performance on these bikes. Some people have actually reported performance issues that may have been caused by iridium plugs.
Don't sweat it, the stock plugs work fine.
-Kit
I certainly agree that Iridiums will give no performance benefits, but they do last longer and that in itself may out weigh the initial cost.
30k miles, checked regularly and doing fine in my TBS.
I just bought dpr8eix-9 for my 01 rs. have not put them in yet. so you are telling me these will not work? I will have to prove they are wrong before they will let me return them. how do you know they are wrong? I wish I would have went with my gut feeling and bought the standard one's.
The motor changed between 2001 and 2002 model years; they don't use the same plugs.
-Kit
The DPR8EIX-9 are for a 12mm plug threads... for the Rocket III.
The 955 and 1050 engines use 10mm plugs. The correct NGK iridium part number is CR9EIX. This is a very common plug, and most dealers have them in stock.
I hope this helps.
Again, 955 engines do not all use the same plug.
1999-2001 955s, as well as the carbureted 750/900/1000/1200 models, use NGK DPR8EA-9 plugs. The iridium equivalent for these is DPR8EIX-9.
2002-2004 955s, as well as the 1050s, use NGK CR9EK plugs. The iridium equivalent for these is CR9EIX.
-Kit
Kit is correct about which plug to use for your 955. It depends on whether you have the Gen I or Gen II engine. They both use different sized valve shims as well and have different procedures for adjusting the valves.
If you have a Haynes manual be very careful that you are reading the correct section for the year bike you have on certain things.
The 9EK is a dual electrode plug, and generally doesn't foul as quickly as a standard single electrode plug.
I wouldn't spend the additional money on the IX plug unless you really only take short trips.
FWIW, my CR9EK plugs hold up quite well despite being subject to lots of 2-5 mile trips.
-Kit
Discussion Starter · #14 ·
thanks for the help kit, i was looking all over the place. i stuck with the regular cr9ek. they fire great. i just hope they last lol. should be ok, they are NGK's.
Glad to help. I replace mine every 18k 'cause the book says to; I bet they'd go 36k now that I have the new-style plug tower seals.
-Kit
As soon as my knee heal's up I will pull the old plug's and see if I have the right replacement plug's. thank's for all the help!
Australian Triumph dealers now advising use of NGK-8EK for our bikes.
I changed mine out at the 20,000k service and used those to replace the 9EK ones that were in there from the factory.
All seems good.
-Kit
For lack of a polite term...
Prove it. ;)
Please... :D
1 - 20 of 41 Posts
