1 - 3 of 3 Posts
So as always I connect my OBD Link to my 2017 XCX 1200 and run trough a few values, so in neutral I check the TPS %, throttle closed I read 0% ,Full Throttle I read 31%, select 1st gear same value, from 2nd gear I read 0% on closed Throttle and 100% at full Throttle, I always thought that it is limited in 1st, 2nd and 3rd gear, clearly not....:rolleyes:
Just took a look at a tiger 1200 xcx map out of curiosity, sad I know :rolleyes:
Don't know which mode is which but in one mode its "limited" to 50.6% throttle in all gears.
Next mode is 74.6% in 1st gear then 100% in the other gears, though it has the usual 85.4% clip just before the limiter.
Final mode is largely the same but with a sharper throttle response.
I'm guessing Rain, Road, Sport in that order, don't know if that's how they are labelled on the Tiger though.
It was in Road mode, will check the other modes also... Didn't think about that... 🤔
1 - 3 of 3 Posts
