1 - 7 of 7 Posts
So, after gooping on some RTV and installing silencers, how long must one wait before firing her up and taking her out for a ride?
Any help, and a one-liner or two, is appreciated.
I use Permatex ultra copper to seal all the joints in my pipes. I wait 24 hours for it to cure.Never a leak.
Fair enough. I've never waited that long, but on the other hand I have had a couple of leaks - I always put that down to not filling the joint properly, but then again...........
What's a Leak Like
I waited just long enough to clean up my tools.
What are symptoms of a leak?
Popping on the overrun is a common symptom, but also just feel around the joint (hands off the pipe obviously) while it's running, you can feel the exhaust blowing out.
Exhaust leak evidence
I had a small black streak at the joint between header pipe and silencer with my original silencers, on the new bike. I cleaned it and sealed it when I installed the new silencers.
1 - 7 of 7 Posts
