1 - 10 of 10 Posts
Hi, i have some question regarding the instalation of the Street Triple Flyscreen, in the instalation instructions of Triumph, they tell to disconnect the battery, do you guys do that, or only disconnect de plug from the instrument panel, thanks :eek:
I guess that is best to follow the instructions, just in case.
I would prefer not to use the words snap, crack or pop when dealing with plastics. These parts are pretty tuff stuff, it's just the thought makes me queasy.
Yep, used the triumphinstructions.com site to get instructions for the flyscreen and windscreen. Installed mine about a month ago and there were no instructions packaged with the parts. Must of been packaged either on a Monday morning or Friday afternoon!
Cool - thanks! That helped. I had almost installed it correctly w/o the instructions, but now see that the rubber seal between the original instrumental panel and it's rear cover is not needed anymore. It will fit either way though...
Is there an online version of the workshop manual as well?
1 - 10 of 10 Posts
