trackdayrider - when you added the front wheel from the speed triple, in this thread, what did you need by way of bearings/spacers etc.? I just got a set of these same 5-spoke speed triple wheels for my 2000 Daytona 955i but the front wheel is completely different (because of the speedo drive issue you and DEcosse mentioned). I think I can figure out how to convert the magnetic speedo drive to 'mechanical' as on my bike (or just find an electronic speedo from a newer bike?) but don't know about basic installation of the wheel...
I just want to be sure that I purchase the 'right' stuff and I'm not sure whether I can use my 'original' axle with the new spacers/bearings or if I have to buy a whole new set-up to install....am I correct in believing that the fork width at the axle is the same? Just checking since you've obviously just done the swap. Thanks in advance
Just adding in a hyperlink from BikeBandit showing the front wheel parts schematic
http://www.bikebandit.com/triumph-motorcycle-speed-triple-2007-front-wheel/o/m17656sch569345
Hoping you can verify what parts I should be purchasing...thanks again!
