1 - 3 of 3 Posts
rememnber how i was have a coil issue, that was causing me to run on 2 cylinders?
well i got another coil today, swapped it for the bad one, and no difference.makes no difference if it is plugged in or not.
so next i swaped ht leads round.no difference, still the same, and if i pull the wires of number 2 coil again, it still runs on 2.
so, the coil is fine, the ht lead is fine, next i check the feeds, and even they are showing the same values as the other 2.what the hell could be causing my problem?
1 - 3 of 3 Posts
