So today is going to be a tinker day. I am installing the header and crossover mid-pipe from a '96 trident, the lower water pipe off a '96 Speed Triple, the lower water hose off (I think) a Ford, and I think a set of one range hotter Bosch Platinum +2 plugs (The NGKs I have in there have just over 10K miles on them, time to swap them out anyway)
I've been thinking, though. I am pondering a bit of ignition advance. I did a little searching on here, and it seems that I could file the mount hole at a rate of .65mm/degree of advance. Factory Pro sells a +4 degree rotor for about $100 shipped. My questions are: How much advance would be useful? Reading here there seems to be some disagreement there, with a couple of posts saying +5 or more degrees would give good results. Thoughts?
Also, if my target advance was, say... +5 or +6 degrees, that would mean increasing the size of the mounting slot in the rotor by 3.25mm 3.9mm. At that measurement, I might wind up just cutting a new slot. Depends on how wide the existing slot is.
I guess the question is- what would be the maximum advance you folks think I could get away with before affecting "streetability" or hitting diminishing returns?
Merlyn
--Has a Dremel and is not afraid to use it!
Merlyn
