1 - 2 of 2 Posts
Discussion Starter · #2 ·
My turn signal idiot lights and Neutral light are yellow.
On 2001 Thunderbird and same on 1998 TBS.
Is that normal ?
Answered my own question: They are yellow because the bulbs are very dim/orange. I just swapped in white LED and now Turn+Neutral are Green!
Also found out that ground mode for the temperature warning light was done wrong. You are supposed to cut black feed from main harness to instrument panel then run new ground to the instrument panel. On mine the main harness was grounded making the temperature warning permanently off.
1 - 2 of 2 Posts
