What to get?
If after you've tried all these good suggestions you still have a problem, I would look at your suspension. Speed wobbles are most often triggered by the front wheel being unweighted. That can be caused by excessive rebound damping in the fork... a bump compresses the fork, and the springs don't get the wheel back on the ground fast enough. That moment of insufficient contact can be enough to initiate oscillations. In these forks, rebound damping is handled by oil viscosity. My personal opinion is that this is made more challenging by progressive wound springs (which I have used on my bike and then removed). They compress so easily through the first bit of their travel that whoever is setting the fork up tries to compensate with heavier oil, creating new problems. (My experience was that they were an especially bad match to Hagons, which seem to have quite a bit of static friction... the fork compresses easily, while the shocks momentarily resist compression).The problem I’m having is a side to side handlebar shake between 50 mph and 60 mph. This is what I’ve done so far but it’s still there:
- new tires (Pirelli sport demons)
- tried different tire pressures
- checked spokes and wheel alignment
- bearings are good
- steering bearing adjustment is good
- everything torqued down to spec
- chain and rear wheel aligned properly
- wheels are balanced
running out of things to check. The bike has progressive front springs and Hagon rear shocks. Not sure if that’s the problem. Any suggestions are appreciated.
I've never understood why Hagons supply and recommend 20W oil with their progressive springs. I run Hyde full length progressive springs, use a 5W oil and played around with the air gap (sorry can't remember what it currently is) which works for me. I also have adjustable fork caps fitted but haven't touched them for a while.In these forks, rebound damping is handled by oil viscosity. My personal opinion is that this is made more challenging by progressive wound springs (which I have used on my bike and then removed). They compress so easily through the first bit of their travel that whoever is setting the fork up tries to compensate with heavier oil, creating new problems. (My experience was that they were an especially bad match to Hagons, which seem to have quite a bit of static friction... the fork compresses easily, while the shocks momentarily resist compression).
That's only real reason to fit one to a Bonneville. For the bike, they add nothing. Just extra weight. There's something wrong with a Bonneville if it doesn't behave itself in the handling stakes.I've never understood why Hagons supply and recommend 20W oil with their progressive springs. I run Hyde full length progressive springs, use a 5W oil and played around with the air gap (sorry can't remember what it currently is) which works for me. I also have adjustable fork caps fitted but haven't touched them for a while.
I also have a steering damper really just because I like them![]()
Checked wheel alignment... did you check front to rear wheel alignment? This is more important to handling than chain alignment.The problem I’m having is a side to side handlebar shake between 50 mph and 60 mph. This is what I’ve done so far but it’s still there:
- bearings are good
I wouldn't say that is totally correct as the damper does stop the frontend from unexpectedly wiping round to full lock at very slow speeds or even stationary, which can easily cause a drop of the bike.That's only real reason to fit one to a Bonneville. For the bike, they add nothing. Just extra weight. There's something wrong with a Bonneville if it doesn't behave itself in the handling stakes.
These are the right questions if you're dealing with a bike that's prone to speed wobbling, which usually means a bike with a lot of power... enough to loft the front wheel on acceleration. These bikes don't have that problem, at least not on stock suspensions and not if they aren't loaded with a passenger or a lot of gear. Something mechanical is wrong. My bet continues to be suspension, but I'm biased by experience. The other explanations offered are edge cases, but possible.Not necessarily ruling out the mechanical, but a couple of quick questions that others might be able to comment on:
a) where is your body weight centered when the shake/wobbles happen, and does changing riding position have any better or worse effect?
2) how much pressure/weight (if any) do you have on the bars when this happens?
To a 13-year-old model?I have read enough of these posts to think someone at Triumph should be paying attention.
As if.......I have read enough of these posts to think someone at Triumph should be paying attention....
