1 - 20 of 45 Posts
By overwhelming demand, this thread will be a write up about my 06 955i Tiger.
I'll start with a little background while my camera battery recharges.
The first time I saw one I had to run over and take a look at what that weird looking thing was. That's a TRIUMPH? They reminded me of a cross between the old 1950s/1960s Italian race bikes and Richard Nixon's jowls.
I had put on around 105,000 miles on my Buell Ulysses and knew that sooner or later I'd have to park it and replace it with something else. How about one of those giant, weird looking Triumph Tigers?
I read a Buyer's Guide and they said 05 was the year to get and I saw an 06 on eBay with 8,000 miles which didn't sell.
I contacted the owner and we struck up a deal so off to NYC on Christmas Eve, 2016 to pick it up.
Traffic, of course, was murder. Shoulda gone on Christmas Day.
The guy I got it from had two Tigers, one he kept in NYC and one he stashed at a friend's place in Florida and he'd use it when he'd go down there on vacation.
I got the Florida bike. Shoulda gotten the NYC bike.
I stopped by to show it off to some friends on the way back to PA and discovered that the first thing I needed to do was buy a new battery!
I got it home and on Christmas Day (after swiping a battery from another bike) I immediately got it stuck getting it off of the truck but a Good Samaritan type was passing by and gave me a hand. I told him that there really is a Santa Claus and he laughed and said he used to do hill climbs so he knows the feeling I had with a bike halfway down a ramp, ha, ha.
I gave it a bath and off to the gas station for a fill up and to bomb around for a bit and then give it a check over.
The first thing I discovered was that the oil was a quart low.
The fellow I bought it from admittedly knew zilch about mechanical things so I called him an unflattering name and dumped in a quart of oil.
Fuel mileage was in the mid 30s so I pulled the air filter and it was FULL of red Florida sand. Uh oh, this fellow was using it as a trail bike so I popped in a K&N and the mileage went up to high 40s.
I got rid of the giant dirt bike bars and stuck on Buell Lightning bars, a Corbin seat which makes the big WAY too tall for me but doesn't give me a welt like the stock seat does, bar end mirrors, a Staintune canister and then a Trident canister, experimented with around 6 different wind shields, new chain and sprockets and went up one tooth on the counter shaft sprocket, Super Mosfet Kit from roadstercycle.com, replaced the IACV lines, put on a real horn, replaced the fuel filter, brake pads, all fluids, spark plugs, discovered that the rear pads have a tendency to drag if you don't clean and lube the pistons and mounts frequently, wrote to Ferodo and got them to list the correct rear brake pad set in their online catalog, that kind of stuff.
Sometimes the oil level would hold steady, sometimes it would vanish at an alarming rate.
Different brands, viscosities, types of oil - same thing.
Exhaust canister outlet is sooty, no oil in the air box. It's being blown out the back, different length dipsticks did not matter a bit.
I poked around on this site and asked the fellows on tigertriple.com what they thought and the suggestions were valve guide seals and one fellow brought up the subject of cracked pistons.
That will make your heart sink!
At around 31,000 it started to sound like it was full of marbles when it was hot and finally, at around 32,500 miles the idle at start up dropped down to around 750 and then one morning it just conked out and didn't want to restart.
I can take a hint, time to smack it with a hammer.
First pic shows Christmas Day when I first got it, second pic shows last Winter with around 30,000 on the clock.
That's exactly like the bike I sold last year. 62500 miles on the clock, and a broken clutch cable was the only non servicing money I had to spend
Several hours of greasy merriment later, the bike's all in giant chunks.
Here's two things that might make things easier for other people:
get a large brass drift and a stout hammer and give each of the T47 head bolts a good smack to help loosen them up (you only want to shock the bolt, not try and drive it through the center of the Earth) and
the head can come off in the frame if you lift up the front right hand corner first, it will clear the fixed chain tensioner blade. If you just try and lift the head straight up it won't happen.
Here's some gearhead porn.
Everybody's garage always looks like you can eat off of the floor, mine looks like it's packed full of crap because it's packed full of crap.
The first two photos shows the old girl as it currently sits with two straps holding the motor up firm. one has a hook stuck in the front casting where there's an unused hole up in the front left. I don't know what the purpose of that is but it came in handy. You'll notice the stylish Hefty bag to keep crap out of the engine while it's awaiting parts.
Photo 3 shows what evil lurks beneath the Hefty bag. Cylinder number 1 (ATDC) is the one with the low compression. It would do around 100 dry, 140 with some oil squirted down the plug hole. The other ones were around 180-190. Numero Uno no es bueno!
Picture 4 shows the oily mung inside of the exhaust ports. The oil consumption isn't confined to the evil Number One cylinder.
Picture 5 shows that the misbehavior isn't confined to just the exhaust side, either.
And finally, picture 6 shows that the valves look pretty much as expected. I see that someone at Triumph puts an X on the exhaust valves so they don't get mixed up at the factory.
As you can see, I have my work cut out for me.
The plan of attack is to clean up and refresh the cylinder head first and then turn my attention to the pistons and see just what horrible thing is going on down there. I have my suspicions on that one.
Thank you. I always enjoy reading the member's rebuild and restoration threads so here's something on what's now an older triple. Seems kind of new to me but time marches on.
I'm really curious as to what's up with that piston so will take some pics when it's out on the bench.
That should be in another week or so as I have to make the liner pulling tool.
Oh yeah, someone said (somewhere or other) that Buell Ulysses turn signals work on this bike.
Not exactly a change connectors and bolt them on for the rear as you also have to cut down the threaded shank.
A little more progress is being made.
My plumbing doohickeys showed up so I could make a liner puller and as it was 95 degrees in the garage and near 100% humidity I figured this would be the perfect time to work on the bike.
And you think I'm having fun. Nope.
Initially I was just going to do liner and piston number one but, of course, on order to remove piston number one you have to pull liner number 2 and get that piston to BDC so I pulled all 3 liners just to get it over with.
The longitudinal scratches seen in the pictures can be caught with a finger nail so it's what I thought, this motor sucked in sand as the previous owner was playing trail rider.
For all of the K&N detractors I should mention that this bike was running the stock air filter and had around 8,000 on it when I got it (and it was burning oil).
I'm happy to say that the piston did not start to disintegrate like what happened on some of the 1050s.
Over the years I've had a few cylinders off and this is only the second one I've seen where the ring end gaps were lined up. Some say not to worry as they rotate under use but I suspect this contributed to the low compression reading.
The head gasket was fine and when my breaker bike's pistons and liners show up from England I'm going to run a FlexHone through all three liners, new rings on all three pistons and new circlips for piston number one.
I'm only going to replace piston/liner number one, the other two look okay and had high compression readings.
The black, slanted line in the last photo is a 1 put on with a Sharpie, it's not a gouge.
Progress is being made.
I bought this bike a few years ago to replace my aging Buell Ulysses. At around 127,000 miles it's just too decrepit to be trusted.
When I took the photo of the Tiger valves in the egg container I couldn't help but think of a neighbor who asked my mother to put a fence up and when it was done, he came over and said,
"Hey, that's not what I had in mind!"
Oh well, head is cleaned up, valves are lapped, new valve guide seals and it's all back together.
7mm silicone IACV line worked just great for spinning the valves around to lap them and I used an automotive fuse puller to press the valve guide seals on, it worked great.
That's the piece sitting in the middle of the head.
Best part was the manual saying to lightly coat the valve stems with molybdenum disulfide grease.
Slob some grease around? You don't have to tell me twice, I'm on it!
Discussion Starter #8 (Edited)
While I'm waiting for my criminally overpriced OEM piston rings and circlips to show up I got the liners ready.
Show me a man who doesn't enjoy reaming out a liner with a set of lubed dingleberries on a stick and I'll show you a Liberace fan who lives with this mommy.
British liner reamed out with American FlexHone held in a Japanese drill and then cleaned with an old Moto Guzzi tee-shirt and lightly oiled with Harley Davidson 20W50 oil.
It's a wonderful thing.
Correction to the previous post: I used 6mm silicone line on the valve stems to spin them around, not 7mm.
Discussion Starter #10
You're thinking of using a boring bar for oversized pistons which Triumph does not offer.
This is just for seating new rings, it doesn't remove much material.
New rings should be here today so tomorrow I can start getting it back into smaller chunks.
Discussion Starter #11 (Edited)
Ring gaps checked, rings installed and spaced correctly, new circlips for pistons #1, liners hit with Hylomar, liners installed, head installed and torqued, 3 motor mounts in place (but still need to torque 3 of them).
It must be 110 degrees in the garage SO tomorrow is another day.
A couple of things I noticed: in the shop manual they mention deburring the piston for the piston pin (if need be).
This must be pretty common and was needed on the one piston I had out. Dremel to the rescue.
Whatever they're using to seal the liners is not Hylomar, it's some sort of brown stuff, not blue.
Gently rocking the liners to clear the rings is certainly different but it will work with enough patience.
Cylinder head goes in from the L/H side and then you need to futz around a bit to get the right front corner to clear the captive tensioner blade.
It cooled down a little bit so the fuel rail, injectors and throttle cable are hooked up.
Discussion Starter #12
A man's gotta know his limitations and mine is 10AM during a heat wave.
Exhaust on, radiator on and filled, oil cooler on, valve doohickeys with the under cap shim on, valve cover on to keep bugs out, front crash bobbins on, started on the wiring and think I'll be pulling the throttle body assembly to reroute things.
Not today, though!
Discussion Starter #13
New filter and oil in, picked up some new spark plugs, installed and timed the cams which took two attempts, installed the cam chain tensioner and, just like the manual warned, valves will require readjustment as a bunch of them are out of spec.
I kind of figured that would be the case SO shim kit and digital micrometer ordered.
By the time all is said and done I'll be able to beat on these motors in my sleep.
The good news is it has really good compression, you can feel the improvement just by spinning it over with an Allen socket.
While I'm waiting for the shim kit to show up I'll busy myself by hooking up all of the electrical connectors that won't be in the way of pulling the cams (again). I'd originally thought the motor was coming out so everything was disconnected. Good time to clean the contacts and hit them with dielectric grease.
With any luck, next weekend it'll be back on the road.
Well done mate, the thought of having to do all that to my bike fills me with dread......I just couldn't be @rsed, with all the hassle having done it in the past !! :frown2:
Discussion Starter #15 (Edited)
I'm not done yet but it's getting there.
I made the job harder on myself by originally thinking the motor was coming out so could have left the oil cooler on along with some motor mounts and a whole bunch of electrical connections.
It's mostly attitude with this type of stuff; it's either a horrible chore which is going to take forever or it's an interesting way to pass the time.
Go for a ride on something else to get in a good mood and then hit the Tiger with a hammer for a few hours.
Not an easy thing to work on but overall it's a well made bike.
They certainly cut some corners but that stuff can be fixed.
Time for a ride and then back to hitting it with a hammer!
I also discovered that my "NOS open box" eBay gasket set was missing a bunch of crush washers that I needed. Guess somebody else needed them more than I did.
Discussion Starter #16
Getting closer.
After a shower and a night's sleep I decided to take another look at the valve clearances when I could see what I'm doing without that mosquito trying to fly into my ear.
Two valves were just a smidge loose SO I said let's see what we've got. I can screw around with that next oil change.
After stupidly not securing the ignition coil connectors properly (note to self: must SNAP down with snapping noise) I got it going and it sounds really good.
No explosions, no shrapnel, no fires, no smoke billowing out of the exhaust, no quarts of oil spewing out anywhere - success!
Kinda.
Two things are going on at the moment: CEL for injector 3 so I have to pull that connection and reseat it and it looks like it's leaking from the radiator cap. Always something.
That will have to wait until tomorrow as I've had enough fun for one day.
Discussion Starter #17 (Edited)
And we're done.
Here's a beauty shot of it spitting out the excess coolant while Molly Dog supervises.
With the radiator cap leak due to somebody being stupid it sucked down coolant like crazy after the first start up so I topped up the overflow tank and now the old thing is self leveling like I knew it would.
The sound is certainly MUCH different than before with a pronounced growl to the motor. Before it was lots of whizzing and maybe some marbles thrown into the mix. Not very inspiring.
For the first road trip I decided to follow the instructions from Hastings piston rings. I figure when in doubt ask the experts.
STARTING PROCEDURE
1. Set tappets, adjust carburetor and ignition timing as accurately as possible before starting engine.
2. Start engine and set throttle to an engine speed of approximately 25 miles per hour (trucks, tractors and stationary engines one-third throttle) until the engine coolant reaches normal operating temperature. Then shut down engine and retorque cylinder head bolts, recheck carburetor adjustments, ignition timing and valve tappet clearance. (Run engine at fast idle during warm-up period to assure adequate initial lubrication for piston rings, pistons and cylinders.)
BREAK-IN PROCEDURE
1. Make a test run at 30 miles per hour and accelerate at full throttle to 50 miles per hour. Repeat the acceleration cycle from 30 to 50 miles per hour at least ten times. No further break-in is necessary. If traffic conditions will not permit this procedure, accelerate the engine rapidly several times through the intermediate gears during the check run. The object is to apply a load to the engine for short periods of time and in rapid succession soon after engine warm up. This action thrusts the piston rings against the cylinder wall with increased pressure and results in accelerated ring seating.
2. Following the breaking-in, turn the vehicle over to the owner or operator with the following suggestions:
PASSENGER CAR AND LIGHT TRUCK
Drive vehicle normally but avoid sustained high speed during the first 100 miles.
HEAVY DUTY TRUCKS AND BUSES
If possible, place in light duty for first 50 miles. At no time should the engine be lugged. Lugging is said to exist when the engine does not respond to further depression of the accelerator.
FARM TRACTORS
Operate at one-half load or less for the first two hours.
(Obviously, not all of this applies to the Tiger but I wanted to provide the full text for their ring seating sheet.)
No problem telling me to give this bike full throttle SO I terrorized the countryside for around 20 minutes, made it home before the rain hit and no oil leaks, no oil smoke, no oil consumption.
This week I'll do a tank full of gas bombing around the back roads and then it should be back to regular service.
Cost was about a grand: used piston & liner, NOS (and pilfered) gasket kit, 3 sets of Triumph rings, 2 Triumph circlips, FlexHone (had the oil), gallon Mobil 1 15W50, Purolator oil filter, 3 NGK plugs, distilled water, gallon of Prestone, 3 Oatey 33402 plumbing pipe test plugs and a threaded rod, some washers and two nuts for pulling the liners, new tube of Hylomar and I think that's about it.
I had all of the other tools and supplies needed.
It took a while and there were times I wondered if I hadn't lost my mind but all in all, it was a fun project.
Best of all, it runs better than it did when I bought it that perfect Christmas Eve from that fellow in NYC a few years back.
I guess I really do like this bike!
Discussion Starter #20
Thank you, I've put about 50 miles on it so far and all seems good.
I just need to go over the bike to make sure that nothing has loosened up and then do another 50 miles of bombing around the backroads before it's back to highway droning duty.
After riding an 04 Sprint RS for 5,000 miles the Tiger feels decidedly different!
1 - 20 of 45 Posts
