1 - 3 of 3 Posts
It seems better than the electric vest because it eliminates the need for a long sleeve sweater, etc. It's sure gets warm - in fact, I can't imagine a situation that would need the highest heating level. It has a high neck collar that I like.
The control switch is kind of bulky and awkward. It comes with an elastic band and you're supposed to strap it to your leg. I hooked it straight to the battery with the supplied harness.
Here's a link.
http://www.compacc.com/prod.cfm/cid/1001005/pid/18247
Cool! Well - warm!
I'm going to move this into our gear forum so that everyone can benefit from the info!
Cheers!
Once you ride with heated gear it's hard to go back to bulking up in the cold.
Last week Ii started using a Gerbing jacket liner. It's like being in a hot tub!
At first I was skeptical that the jacket alone would help keep my hands warm but it does help quite a bit.
1 - 3 of 3 Posts
