1 - 3 of 3 Posts
I have a serious fuel leak that appears to be coming from this fitting. I've replaced float needle, float bowl gaskets, adjusted height of float but leak continues. Can anyone help in removal of this part to get to the o rings that I believe are causing the leak?
Ok, from a fellow member sharing info. I saved this tidbit.
Fuel leak by the left carburetor on 2001 Bonneville. It seems to be coming from the T-fitting/fuel crossover tube (the one that the fuel line attaches to) where it enters the carbs. Hermy's has the cross over pipe with what they call 'U' rings.
NAPA :AS568-010 (OD: 3/8 in.; ID: 1/4; CS: 1/16) on both sides works.
Hope that helps. Not sure since you did not really describe where the fuel leak is coming from.
Hope you will report back what you find.
1 - 3 of 3 Posts
