Hey guys,
I'm in the process of removed my aftermarket pipes to rewrap them. I've already successfully taken off the left side and rewrapped, but how to I access the hex bolt behind the rear brake to remove the left side exhaust?
Thanks for your help,
Travis
You have to remove the sprocket cover and the footpeg bracket that side. If you're careful you can leave the rear brake master cylinder in place.
The footpeg bracket has 3 bolts - 2 holding it to the frame, and a 3rd clamp bolt on the swing arm. You only need to slacken this one.
