1 - 2 of 2 Posts
Sorry for the new topic, but I forgot how this crap works.
It's a 2007 Triumph Sprint ST that used to be quite fun...
StreetShark.
First of all, look at the handle that is recessed into the top of the case beside the lock, and notice that the "D" shaped plastic panel within the handle shape is actually a pivoting panel that can be activated by pressing on the side closest to the lock.
Second, insert key and rotate clockwise to the "open" position and press on the previously located catch release, the catch panel will pivot inwards and the case will unlock.
Third, pull on the edge of the case lid and it will open.
Note that the handle has nothing to do with opening the case, it is used for removing the case from the bike and/or carrying it. It will pop up from the stowed position if you rotate the key anti-clockwise to the release position.
Keef.
1 - 2 of 2 Posts
