1 - 9 of 9 Posts
Hi all
I am wondering about improving the front brake performance. Wondering about feeting a floating disk 320mm ( from yamaha or other bikes that fit the same...) or brake pads... All advises are welcome.
EBC now state that their MD629LS 320mm floating disc fits classic triples. Some have used a Harrison or Pretech 6 pot with a stock disc. If I had the cash I'd probably go for the EBC disc & a Pretech caliper, but EBC HH pads in a stock set up is an improvement alright. I believe the stock brake lines are also braided, just covered in black plastic?
I believe that the early brake lines were just rubber and the later ones were plastic covered braided lines.
Fitting of braided lines will make a big difference to an older bike.
Front caliper
I've got a Berringer front caliper on a Thunderbird and find it just as good as the twin disk set up on my sport.
My 95 Tbird has a braided hose as standard. I use the standard disc with Harrison 6 pot caliper and a larger front mastercylinder (you can source a 2nd hand Kawasaki and swap the cover plate over. This gives a massive improvement over te standard setup and is worthwhile if you're keeping the bike. Also try Hagon rear suspension unit and fork springs which will transform your handling.
It really depends how much you wish to spend.
Personally I prefer to double up on discs.
A jap front end may be an option, I suppose.
I used a TBS front end & upgraded the master cylinder & calipers too.
I currently have a pair of 1980's P8 Brembos with stainless pistons.
They seem to be working well, but are not a straight bolt on mod.
Nige. :cool:
The HH pads will wear out your stock disc in a hurry. I don't think a floating caliper is going to help that much on a stock system, though it will be better with the HH pads! '95-'97 T-Birds came with a rubber hose line standard, and most people changed that out right away...
If money is no object, the simplest thing to do is the 6 pot conversion. You will then want move on to the front suspension, due to fork dive... :D
1 - 9 of 9 Posts
