We give up...this is a desperate cry for help.. Where the flipping heck are the instructions to change battery in the remote key fob for Tiger 1200 XRT. If it’s in the user manual then it’s well buried
Administrator
Welcome to the forum!
The Tiger Chat forum is where you can connect with other Tiger riders. The folks there will best be able to assist you. Introduce yourself there, post photos of your Tiger, and join the banter.
http://www.triumphrat.net/tiger-chat/
Please complete your user profile so that we may see where you are from and what you ride as you post throughout the forums. Thanks!
http://www.triumphrat.net/profile.php?do=editprofile
Connect with local riders in the RAT forums. If you do not see a thread for your area, please start one.
http://www.triumphrat.net/rat/
You may also find local riders and local events in the Rides and Events forum.
http://www.triumphrat.net/rides-and-events/
Please share your rides with us by posting photos of your rides in the Ride and Trip Reports forum.
http://www.triumphrat.net/ride-trip-reports/
Enjoy some off-topic and often humorous conversations in the Biker Hang Out forum.
http://www.triumphrat.net/biker-hang-out/
There is much to our forum, so please make yourself at home, browse the forums, and join the conversation where ever it may interest you. We are happy to have you here.
Cheers!
Did you ever get an answer as I am looking at opening the key fob to change the battery as well I was able to remove the silver screw but don't want to pty the rest open in fear that the plastic will snap?
Take the screw out then separate the halves by pulling up on the edge next the screw. Its a bit tight but it’ll go. There is a gasket the may stick be careful not to rip it.
Take the screw out then separate the halves by pulling up on the edge next the the screw. Its a bit tight but it’ll go. There isca gasket the may stick be careful not to rip it.
Thanks very much... Yes the two halves are extremely tight but did come apart. was worried about snapping or breaking a plastic tab.... CHEERS!
You'll find it on page 94. But be warned my dash said batt needs changing ( new bike 12 weeks ago so not used much Lockdown!!) changed batt then tried on bike .... took ages before it paired with it. All ok now
Bizzarley I metered the old battery and its reading Full Charge will be having words with Triumph.
to change batt press the centre button till it shows red on the light remove the 1.5mm Allen fixing slide batt out then slide new in replace cover retighten Allen fixing but don't over tighten.
Good luck
