1 - 20 of 22 Posts
The Golden Rule in any restoration is to start with the most complete and authentic bike you can find. Even a project that's described as 95% complete will take a lot of time, money and effort to find the missing pieces. I knew this. I knew it from previous experience and yet I still thought it was a good idea to build a bike starting with just a front frame section and the numbers matching crankcase halves. My reasoning was that it was never going to be a Concours standard show-winner so what could possibly go wrong? Here's what I started with, 1967 T120R frame and crankcases bought off Ebay Motors and shipped to the UK with all the associated costs and paperwork.
The oil seal for the drive side main bearing had also been butchered at some time and was siliconed and centre-punched to hold it in place. This didn't overly concern me as I was intending to delete the timed breather and convert the engine to 1970 spec with crankcase breathing via the primary chaincase. The crankcases were rather grubby after 50 odd years of use and abuse.
Gas Metal Auto part Titanium Composite material
However, once the rolling chassis was built, complete with period flanged-alloy wheel rims and ventilation holes cut into the front wheel hub, I decided that I didn't want another bike with rear-set footrest and clip-ons and decided to build it as a standard T120R but subtly modified as a bit of a street sleeper.
Tire Wheel Fuel tank Vehicle Automotive tire
Discussion Starter · #9 ·
To repair the chain damage to the crankcase I cut a piece of ally casting off a scrap gearbox casing, shaped it to fit and had it welded in at my local welding shop as I don't do Tig myself. When dressed back is almost invisible and is hidden under the new breather outlet anyway.
Discussion Starter · #10 ·
I had to source everything other than the front frame and crankcases which took about 3 years whilst I was doing other projects. I found really good lightweight crank from a 1966 bike, it was on standard diameter journals which were probably ok to use as they were but I had it reground to - 0.010" and fitted a new sludge trap. I like to ride my bikes hard and don't generally use standard conrods which are all getting on a bit now anyway. My favourite rods are made by Arrow in the UK, I've had four sets in my T150s but they don't make them for twins and so I went with R & R billet alloy rods. I have to say they are rather nice. (y)
Font Material property Rectangle Metal Fashion accessory
Discussion Starter · #12 · (Edited)
As I didn't have any transmission or clutch parts I decided to go with a conversion to a 5 speed gearbox as I've done on my T150s previously. This means opening up the clearance hole for the 5 speed high gear to go through the drive side crankcase. I also blocked off the breather tube in the lower crankcase and fitted an elbow from a TR5T to run a breather pipe to the end of the rear mudguard.
I fitted a belt primary drive with alloy clutch basket and I run the primary case dry so I drilled the three oil return holes as low as possible. I also removed the primary chain tensioner pivot which increases the breathing between the crankcase and primary case. (it's still in place in this picture) The crankshaft oil seal was left out. With new cams, fitted without the timed breather disc, the bottom end could be reassembled.
Automotive tire Window Motor vehicle Rim Gas
Discussion Starter · #16 · (Edited)
youre running a dry belt but you drilled the three oil holes. youve left out the crank seal?
what kind of belt is it?
It now breathes through the main bearing into the primary case and out through the new breather pipe so the crank oil seal has to be removed. The three holes are to let any oil that blows through the main bearing return to the crankcase so the primary case doesn't fill with oil. The belt can be run wet or dry, it's a 'Megapower 2' AT110 800
Cutting mat Rectangle Packing materials Adhesive tape Masking tape
Discussion Starter · #19 ·
With the engine back in the frame I assembled the top end. The cylinder head is from a 1969 and has had some porting work done. The pushrod tubes are billet alloy from TriCor. Carbs are 32mm Amal Premiers with the stainless steel inlet stubs bored out to match, also from TriCor. Cylinder barrels are new Aerco as per original and I sourced a pair of NOS genuine Hepolite standard size pistons and rings.
Discussion Starter · #20 ·
Due to the cost of having parts painted I decided to have a go myself. I found a very good tank on Ebay which had the tank badge holes filled with solder. These cleaned out quite easily with a bit of heat and then re-tapped. Lots of rubbing down left me with his.
Helmet Plant Motor vehicle Headgear Table tennis racket
Automotive parking light Land vehicle Vehicle Automotive lighting Hood
1 - 20 of 22 Posts
