1 - 3 of 3 Posts
You should check it every time you lube it, about every 300 miles or after a ride in the rain, etc.
If you aren't particularly hard on the bike it should seldom need adjusting. I adjusted mine at 600 miles and it is still fine at 6500.
Keep it on the loose side of the recommended range. Better a slightly loose chain than a tight one.
monte :cool:
1 - 3 of 3 Posts
