1 - 10 of 10 Posts
Speedy is now four months old and has only done 3000km of mostly fair-weather riding. It lives tucked up in my garage, safe, sound and dry! It gets treated to a wash and polish each week, carefully dried in the warm late-afternoon sun.
And yet...
Over the past few weeks I notice that the bright polished aluminium that support the rider and pillion foot pegs are showing serious signs of deterioration -- aluminium oxide film forming on the metal surfaces particularly in the corners and crevices.
How can I stop the rot? Has anyone else experienced this problem? Should I have the parts bead blasted and lacquer coated? Maybe someone could give me some better advice, based on experience?
Salty (sea) air will cause corrosion issues if you are down wind of the sea, and sometimes even if you are upwind - due to even minimum salt content in the soil/dust.
If you have a lot of lime in the water, you will have corrosion issues - I have it bad where I live.
I use a filter on my hose for washing my vehicles. Even the Mr. Clean filtering/washing system will work well.
I occasionally use a product called CorrosionX sprayed on the fasteners and other bits and pieces to remove and prevent corrosion.
I hope this helps.
[ This message was edited by: Devious2XS on 2007-01-13 07:47 ]
Its your location, and how close you are to the sea...also, most areas close to the coast also have a great deal of salt in their water sources...Use a filter like Dev said or just powder coat your parts.
I got a few squid friends that ride Suzuki's in the Corpus Christi area and they always get some form of corrosion...their solution is powder coating.
I may sound like a tard but I usually use gun oil on some areas of my bike...it works for my guns.... :hammer:
+1 I made the BAD mistake of taking my 72 Cuda to coastal NC for a couple of years (about 28 miles from the water). The vinyl top absorbed a lot of salt content and the entire roof was trashed within those 2 years. Shoulda left it in IL for certain. Decided to get rid of it since it wasn't worth anything from a collector standpoint (idiot before me changed the dash pad.......including VIN tag), I got the same amount I paid 10 years before (and I swapped a 360 into and kept the 340), so it was fun while it lasted. Now I just need a shell for the 340 powerplant.
[/quote]
Hey is that a steel crank 340? I have a 71 Challenger convertible looking 4 one of those...
1 - 10 of 10 Posts
