Can somebody explain how these things mount. Would you cut the end off the grips?? How do they stay in the handlebars?? I think I would like a set on my drag bars.
TangoMike
bar end mirrors
you need to cut off end of grip to insert expanding bolt as dave m said its like a rawlbolt fitting normally its an allen key insert it into handlebar end and tighten it,it then expands and grips the inside the more you tighten the more it grips
I put something similar on my enduro bike. Be careful how you cut the grips. I chewed mine up with a box cutter. If I was to do it again id use an exacto (sp?) knife or even my dremel tool to get a nice smooth cut.
Thanks. I figure I will "sacrifice" a pair as an experiment.
TangoMike
