Hi guys.
Fist of all, I've tried searching.
I found little information in regards to my unique problem.
Here it goes...
The engine is smooth up to about 4500RPM when it starts buzzing putting my hands to sleep after 10-15 min. After about 5500RPM buzz becomes more like hi rev vibration which doesn't put my hands to sleep.
The engine speed falls right between my cruising speed of 65-70MPH. The vibration/buzz is present at about 4500RPM regardless of gear it is in. It is quite discouraging to ride it at sustained speeds for longer then 30 minutes, even though I have ThrottleMeister which helps a lot.
Performance wise my Trophy takes off like a stung rat and does not exhibit any unusual drive-ability problem except dreaded vibration.
Thought it was chain as I've read during research. At any speed I can de-clutch and rev the engine up to duplicate the vibration so I believe it isn't chain related.
Im seeking forum's suggestions on what might be wrong with the engine before I plonk some kelp at vulture's den |dealership|
Here it goes...
