Hi, I have a 98 Tiger 900 changed plugs and coils also had carbs replaced and set up as apparently had the wrong carbs on it!! Problem I have now is surging/missing, it won't go over 80-85mph, it feels like something is pulling it back. You can feel like it wants to go but it won't go past that point! Can anyone help and point me in the right direction please!!?
Could be a fuel supply issue, not enough flow would do that. Have you checked the tank? Is it clean? No clogs? Fuel filter is good?
Hoses aren't crimped or pinched?
Your float moves free? Doesn't bind going up/down?
New carbs have good gaskets? No loss of vacuum?
Does it do it only when you get to speed, or does it do it also under hard acceleration?
