I have just taken the head off my 05 Thruxton for porting/polishing/flowing. I managed to get the cams out thanks to the service manual, but had some trouble when removing the cam drive gear. I carefully removed the bolt and shaft from the gear, yet somehow still managed to drop the thrust-washer into the crankcase! DOH!!!!!
I got the washer out ok, but when I went to put the cam
drive gear/shaft/thrust-washer set-up back in I noticed there is quite a lot of play... ie the drive gear moves a few mm back and forwards along the shaft???
I am wondering if I have dropped another washer somehwere even though according to the service manual I have it right.
Is the gear supposed to move along the shaft like that? Is it the cam chain guides that hold it in place?
Any help will be greatly appreciated so I can sleep at night!
Cheers - Turkey
If your engine serial is under 186916, then you have a thrust washer on both sides.
186917 and up - one thrust washer.
There's also some low serial numbers that have a spring washer on the right....
Thanks guys
Yeah, going by my engine # Im supposed to have the same set up as you Sweat - it was the "death washer" I dropped into the crankcase. Im pretty sure there are no other missing parts, but the cam gear was definitely moving along the shaft :mad: I will have another look when I get my head back and let you know.
Cheers - Rhys
