So I got my LSL kit for the Speed Four. Seems to me the longer brake line isn't neccessary but I can't seem to route the throttle cables without them engaging the engine as I turn to the bars to the far right.
What's the trick?
As it is I have about an inch of bar sticking out past my grips. I guess I can bring them in even tighter but that seems strange.
Also do you shave off the plastic pin on the switch mounts? The pin went into a hole in the clip ons that does not exist on the bars.
2020 T120 Black
did you take the tank off? that's how i routed mine....with the tank off, in and around the air box and back out the other side
as far as the pin goes..you can either drill a new hole or shave the pin off...i did both. combination of to much beer and just wanting to be done
good luck
Right on.. I was thinking about that over sushi/sake tonight.. Thought if I pulled the tank I might be able to route the throttle cables to the other side of the head. I'll try that in the morning..
Alright so I've got the cables all routed finally for the life of me I can't figure out the little bracket for the brake fluid resevour. I presume it attaches to the brake lever mount bolt but I no matter which way I put it the mirror seems to be in the way. Suggestions? Light on the subject?
