So, my 71 bonne is fouling (black sooty) left plug. Compression is 170 left (trouble side), and 150 right. Checking everything. Since it is winter and can not start bike, battery out, stored, etc. I was checking the electric, since I thought spark might be weak for high compression side. I followed the meridan lucas document this site, I wonder if anyone can tell me what the results mean in practical terms. Coil resistence was slightly low. Anyone measure theirs?
So here are the results:
Voltage tests:
Man it is cold in the garage. Started by testing the volts to and through coils. Everything seemed to test Ok since battery was so cold.
Except on the good running side, black yellow leads, the voltage measure to points side of the coil (+ side) was rather high, around .4 with the points closed. In fact at one point it read 12. I snapped the points open and closed a few times and it came down to .4 .
This would indicate that side b/y points are being weird, dirty, something. I cleaned them just before that result.
The bad running side gave a result of .12 with its points closed.
n the voltage test refered to above,
The test were performed:
1) From battery ground to power (or -) side of coil.
2) From battery ground to + side of coil with points open
These measurements seemed norma, but were
lower than 12V, but it was awfully cold and battery V itself kept dropping.
3) From battery ground to + side of coil with points Closed
It is on this test that I got .4 on the right side which is the good running side and .12 on the side running badly.
The expected was supposed to be 0 or at least lower than .2
I assumed that the points were just a little dirty, but after the good resistence test on them, I wonder where the voltage is coming from.
I should have done a further test to end of plug lead.
Any ideas? Sound normal?
Results of resistance tests:
Coils:
Primary windings:
Left = 3.9 to 3.4
Right = 4.0 to 3.4
Expected = 4 to 5.5
Secondary windings:
Left = 4.53
Right = 4.76
Expected = 5 to 6 K
High Tension Casing and Metal Casing
Left = Infinite
Right = Infinite
Points (and I did not know what to set meter on):
Left:
Closed = 0
Open = Infinite
Right:
Closed = 0
Open = Infinite
Condensers both tested good, runing through some numbers pausing at 20 something or other and then after no more than 2 seconds holding at infinite.
Voltage tests:
Coils:
Primary windings:
Left = 3.9 to 3.4
Right = 4.0 to 3.4
Expected = 4 to 5.5
Secondary windings:
Left = 4.53
Right = 4.76
Expected = 5 to 6 K
Left = Infinite
Right = Infinite
Left:
Closed = 0
Open = Infinite
Right:
Closed = 0
Open = Infinite
