Hi,
So first off here is a little background information. I bought a 2009 savage title Bonneville from crashedtoys. It had been layed down on its right side. The mechanic that checks the bikes out for QCSA said that the bike started when you jumped the relay... I took his word for it, and after reading the posts here on bonnie relays , I ordered a new relay. I also ordered a stator cover from a speedmaster as the cover was cracked. Stator came first so I replaced it. The relay came in a few days later switched it out and no go.
Then I realized that I had no headlight. I had already checked the fuses so I cracked the headlight housing and I found this.
What is this? Light switch bypass?
When the the top two wires connect (White and Beige I believe) the headlight turns on... even if the key is not in the ignition. (happened by accident). I do have juice in the battery but but the meter reads right at 12 volts at the battery terminals so it might not be enough juice to get it going.
Help me out I want this old girl to run.
What are these cut wires in the headlight housing?
Is there a tip over sensor I need to check?
What do i do?
What do i do?
