1 - 19 of 19 Posts
Hi folks,
Any recommendation on a helmet lock / holder to install on a '16 T120?
Could be with or without keys, if the saddle lock acts as security.
(PS not sure that's the right term, I mean some kind of hook under or next to the seat where I can put my D-ring or strap helmet when I leave it on the bike).
Hi folks,
I use this on my Speed Twin:
https://smile.amazon.com/gp/product/B00BLPS29E/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
This on my Tiger 800 XRt:
https://smile.amazon.com/gp/product/B002F85VQS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  • Like
Reactions: saddlebag
  • Like
Reactions: ranger995
Just in case you’re not aware,
The bike has a hook for this purpose.
Some people find it difficult to fit their helmet, but I’ve never had a problem.
Thanks MotoChooch and Pudge, will have a look at those. Like the ajc one looks very discreet although would need another key I guess.
@in_stereo, thanks for the built-in tip, I've tried that one (wasn't sure what it was but thought it could be the hook), but my D-ring doesn't fit under, maybe I can lift it a couple of mm with pliers, and see if the saddle still closed properly. Will check!
I found it a pain because the built-in one is hidden by my throwover saddlebags.
I made up a length of aircraft cable with loops crimped into the ends that I can loop through the d-rings and the bike hook. Its long enough to do my wife's helmet as well.
I also made up a longer one that will go through the arms of my riding jacket if I want to leave it with the bike without it going missing.
  • Like
Reactions: aj7840
Discussion Starter #10
Thanks for the tip, yes in fact with the bags it won't work. For those instances, I've in the bags also a steel cable with lock, long enough for two jackets and two helmets.
Without bags though I don't want to carry it always around with me and the helmet lock built-in works a charm.
Speed Twin doesn't have that :(
  • Like
Reactions: coldeskimo
We do have these loops under the seat. Any one know what they are for?
Without bags though I don't want to carry it always around with me and the helmet lock built-in works a charm.[/QUOTE]
I didn't use cable that was that heavy. I used cable that was about the same suze as a throttle or clutch cable. I keep it coiled up under the seat. I also don't use a lock. I will either thread the cable through the d-rings and put both loops onto the hook, or I'll thread it through the d-rings, then thread 1 end of the cable through the loop on the other end and put 1 loop on the hook.
Hi folks,
This is what I used on my 2017 it's actually a combination of 2 helmet locks I mounted it on the front fork so I could still use my saddle bags.
1 - 19 of 19 Posts
