1 - 3 of 3 Posts
I have pick up a pack of heilcoils to fix a screw on my speed four and just have some questions if anyone can help, it says 1/4" (6.3mm) drill size for the hole, do i use a 1/4 for the tap or something bigger/smaller? Thanks for any help.
If you don't know what you're doing using a Helicoil wrong can be a path to an expensive repair.
IIRC with a simple Helicoil Kit you drill the hole to the specified drill size, then use the Helicoil tap, then use the tool to insert the Helicoil.
2009 Bonneville T100
Indeed. Helicoil taps are 'specials'. You need to purchase the correct helicoil tap, and usually also the drill.
1 - 3 of 3 Posts
