1 - 9 of 9 Posts
1999 Sprint ST 955i
Issue: Headlights not working as expected. The following is my the steps and the results.
  • Ignition switch to on. Lights switch to on.
Left headlight working. Right off.
  • Switch to high beam.
Right headlight switches on. Left headlight switches off.
  • Switch High beam off and push “Pass” switch.
  • Left headlight is on, stays unchanged. Right headlight comes on.
Ok, I assume you've checked the bulbs? Swapped them over too? Do they share the same fuses?
What's normal behaviour for 955 headlights? Both on for low and high beams?
Someone correct me if I'm wrong, but didn't pre-2001 955i Sprints have some interesting lighting set up, and you could get a dual-relay set up so that both lights would turn on for both dipped and main beam use? I was trying to search it, but was having no luck just now finding that tidbit.
Interesting. That would be good to know, might be working to spec then.
Yes. At least in France the bike was delivered that way. You may add two plain automotive 12V relays as stated above in the empty sockets.
@DEcosse: I thought In California those two extra relays were stock.
1 - 9 of 9 Posts
