the headlights on my 675 have sarted to dim and get brighter wen ridin, doesnt seem to have any affect wen i power on or off. jus flickers for a while then stops?? any ideas or salutions to fix this would be brilliant!:)
I would guess your battery is getting tired. Otherwise, you have a charging system fault, but I doubt it. If it was a charging system fault, the bike wouldn't run after a while.
Will is probably right - It is most likely the battery. It could also be early signs of stator failure. If one or two of the winding poles is starting to fail, it can cause pulsing in the generation of electric current.
Good luck getting it sorted...
