Yep, they did on my motorcycle. You'll need the tube pieces and the brackets, the rubber O rings are the same.
Just check
The thruxton top triple tree i slightly different. I am not sure if this applies to the low bar thruxton as well as the later high bar. So before you part with your hard earned might be as well to check with the supplier with your measurement. Maybe the different thruxton owners can measure theirs and let you know.
they fit fine - but those on the clip-on equipped Thrux are shorter and will leave a gap on top. Here's on my bike, flipped around to move the key to the right side + lower the headlight. And temporarily fixed with black tape
Oops, forgot about that. I made a spacer out of plastic tubing for mine.
