After reinstalling factory headers, new crush washers and everything torqued to spec, am I done? Ran through a heat cycle and cooled off, rechecked bolts and they were no longer in spec. Do I continue to tighting untill they stay spec or leave alone after initial torque of the bolts?
I would re-torque to spec. If you don't there is no harm as long as they are not leaking.
Thanks back2-2, thats what I did but after every heat cycle the header nuts are once again not to spec torque. I know the nuts are not backing off because I marked them with paint. Eventually the crush washer will crush all the way and should stay to the right torque but not sure this is the right approach.
Yes but you don't want to crush the crush out of the washers or the sealing factor may be compromised. Just the one
re-torque should be more than sufficient.
Sometimes crush washers get so smashed they distort if over torqued.
Think also of it this way - when the bikes leave the factory they do a quick run up & ship. They do not go and re-torque the header nuts.
Welcome to the site also. Glad to have you aboard.
