I just got a competition werkes exhaust.
Couple questions
New to the TuneECU
1. What tune should I load, and where can I get it from.
2. Can I use a 07+ header in order to put the O2 sensor back in since the 06 with the CW exhaust deletes the 02 sensor
Need to look at the tune ecu site and match your VIN #, model (ABS, or non-ABS) and find the arrow low. That is a good starting point.
As for the header, I'm not sure!
Yes the 07.5 header will bolt on to any 05-06 model.
You don't need to though . There are tunes that turn the o2 sensor off .
The CW pipe does not like to hve the sensor messing with it anyway . Set the new map , turn o2 sensor to off, reset the adaptive tables , ride . I have a few good CW maps , pm your email address to me and I'll hook you up
Awesome! thanks for the help the exhaust sounds killer except for the popping lol
I read a few posts about the oxygen sensors that is why I thought about adapting it with the later model headers.
