1 - 19 of 19 Posts
I priced a set of 07 handel bars for my 05-06 Sprint and was told $240 Aussie $.....EACH and they couldent tell me for sure if I would have to buy any new cables...so its good that you asked this question.
rgds Sean. :cool:
On 2007-01-14 06:41, PeirreOBollox wrote:
I am considering this optional extra but at £150 GBP is it worth it?
Pidcocks of Long Eaton are putting them on their new 07 ST demo bike, so you could arrange a test ride there and check them out before coughing up the cash.
Discussion Starter · #7 ·
my local dealer has beeen told by triumph not to fit them on the 2007 demo bike
rgds Sean. :cool:
the kit I quoted the £150GBP on
A9638022 ABS model (£149.99GBP)
A9638023 non-ABS model (£149.99GBP)
is supposed to include an extended clutch cable and front brake hose in the price.
which is a good idea as I find the standard clutch cable routing on my 06 tight enough as it is, where it goes around the headstock.
though I understand (though someone may correct me) if you want the headed grip kit they require longer cabling, so they have brought out a different heated grip kit to go with the new higher bars
rgds Sean. :cool:
You are being lied to Sean. The kit is £150 and includes both left and right bars, plus all the extended cables and hoses required.
G
Considering these myself had Genmar risers on my trophy before the sprint was not keen on the fit and look .
I am interested to know if they affect the handling very much ie turning in and such feels pretty good as standard could do with taking a bit more weight off my dodgy right wrist (yet another motorcycling injury from my youth).
Drewsprint6,
I fitted the Genmars over 12 months ago and are fantastic. I have had both my wrists broken and cannot straighten my right arm. With the Genmars fitted I have no problems with either my wrists or my right arm. Before I fitted them I had a fair amount of pain in my back and wrists. I lenghthened the clutch cable by 32mm. All in all I very pleased with the Genmars and they took about 1/2 hour to fit. Hope this helps, safe riding.
The Tankman
:upthumb: :upthumb: :upthumb:
[ This message was edited by: Tankman on 2007-01-19 04:31 ]
Discussion Starter · #14 ·
My local dealer tells me the kit will be available from triumph from the 1st of march, and pre-orders are being taken.
Edit: I`ve decided to go for the higher bars and have ordered them along with heated grips. so I should have them after I come back from daytona
I`m trying to negotiate a discount on the labour charges and additional materials atm
[ This message was edited by: PeirreOBollox on 2007-01-20 11:06 ]
1 - 19 of 19 Posts
