21 - 38 of 38 Posts
Those are the HD Road King custom saddlebag. Looked over the whole web for different mods and qualities. These are the ones that I like best.
ABS structure covered with real leather.
Opening mechanism is a with a latch in the inside opened by a button in the back.
Mounted with quick release ghost brackets and put a little piece of rubber between the bottom of the bags and the rear dresser bars to eliminate vibration, which resulted very effective.
I~ve done some 1,000kms with them fitted and they are great!
Cheers
Thank you for responding, I purchased some new ones off Ebay and purchased some EZ Brackets specific to the T-Bird SE. I'll remove the "Road King" don't want to rub any HD feathers the wrong way you know. I'll put some nice reflectors in their place if it leaves a mark after removal.
I wanted to remove the RK badges but after started, I noticed that it could end up in a butchery. Replaceing them with reflective stuff is a good idea. Please post pictures once you finish.
Here is the HD Road King Classic Bag De-Badged. Removing the RK badges was easy. They're held on by three Cap Nuts, I just used a car body plastic fastener removal tool that I worked underneath the nut and popped it off. Took about 3 minutes per bag. Replaced the Badges with HD Reflectors as they were the right length and width to cover the impression left by the RK. Waiting for my EZ Brackets to arrive so I can finish mounting them now that I have the new Russell seat mounted.
Well done Daycruiser!!
The reflector looks good and you will have no one hassling that you are riding a TBird with "other's" bags
Do you have a photo of the tool you used to remove the cap nuts? When I tried, it was kind of difficult for me.
How did you stick the reflector?
Is there a part number for them?
Isn't the leather "looose" where you removed the fasteners?
Thank you!
Marcelo
Thank you!
Marcelo
The Reflectors have an industrial adhesive pad on the back, they stick very well to almost anything. They are HD Part Number: 59288-92 and 59287-92 (left and right). I found them on eBay, I think I saw some the other day while looking for something else. I put a small amount of silicone sealant in each hole that the badge left when I removed it to make it water tight. The leather is not what I would consider loose under the badge as it's all one piece. It may not be completely flat due to the badge impression but it didn't affect me what so ever. Those babies are stuck on there very tightly after they cure overnight. The tool is a auto body trim removal tool and costs less than 10 USD. Any auto parts store has them. I'll post another pic after the bike is all together with the bags and seat. Thanks for putting me onto the bags, I really like them. Cheers!
Thanks Daycruiser. Very clear explanation.
Since I can't get the tool here, I will make it with an old screwdriver.
Look forward to your photos!!
Daycruiser,
Those really look good; I'm inclined to look for a set myself. I would like to see how they look mounted though; please post pictures when your finished! Good job.
HD Custom Road King saddlebags
HD Custom Road King TourPak. SS laser cut rack.
Midsize windscreen with extension to ride over 150km/h WITHOUT buffeting
Kickstand extension
Daycruiser this looks terrific.
What make is the seat, I haven't caught up with that in the threads?
cheers
Blindaussie
Thank you for the compliment. I'm pretty jazzed about the seat and bags. The seat was custom made by Russell Day Long, http://www.day-long.com/ This is the second seat they've made for me and both have been flawless. I'll be posting my seat on their web site, to date they don't have any T-Bird pics with their work. Many thanks to Eskerinola for putting me onto the bags.
Wellcome to the two people club of HDRK bags!
They look great!
I tilted them a bit to follow the exhaust pipes.
How good are the Easybrackets?
Hey Daycruiser;
I forgot to tell you that I found that the bags vibrate too much due to the weight and may be the cantilevered position. I added a piece of rubber between the rear dresser bar and the bags, glued to a piece of vinyl and the vinyl to the leather. vibration is gone!
I did the EZ Brackets because they had a specific T-Bird SE version, meaning they had specific hardware to deal with the removable backrest. Other than that they seem to work fine and mounted easily. I had more trouble adapting the bags to the bracket than anything. The bags are molded for HD so things didn't exactly fall in the right places on the Bird. I also have a passenger (read that wife) that rides in the warmer weather a lot so I had to take her short inseam into account on how far forward and high up I could place the bags. Next year I'm going to change the exhaust system and get something that doesn't sweep up in the rear quit so much as the stock pipes do. I also want to take out the CAT at the same time. The brackets are pretty ridged so I don't anticipate any vibration issues and I kept them on a horizontal plane to the bike itself.
Are those bolts protruding into the bag? Not sure if I was seeing the picture correctly, made me think they would snag everything.
You are correct.
I have Easy Brackets on my America and when installed per their instructions they can damage your cargo. They come with long alen head black bolts that can rust. I went to the hardware store and bought shorter stainless steel alen button head bolts (mark your old black ones to get the correct length) and stainless low profile lock nuts. Install them the opposite way with the smooth round alen head inside the bag and the nuts on the bracket side. Yes the nuts will fit in side the Easy Bracket box and not contact the lock it does require extra work though, just drop in a crowsfoot to hold the nut while you tighten the bolts.
Fair enough.
As to the exhaust, I fitted the Hog Slayers -without CAT- and I'm pretty happy with them. I do like your seat. I wish I knew about them at the time I bought mine...
You are correct.
I have easy mounts on my America and when installed per their instructions they can damage your cargo. They come with long alen head black bolts that can rust. I went to the hardware store and bought shorter stainless steel alen button head bolts (mark your old black ones to get the correct length) and stainless low profile lock nuts. Install them the opposite way with the smooth round alen head inside the bag and the nuts on the bracket side. Yes the nuts will fit in side the Easy Mount box and not contact the lock it does require extra work though, just drop in a crowsfoot to hold the nut while you tighten the bolts.
I have the same mounts and I saw the same thing so I cut and tapered all the bolts to the proper length. Your revision looks much better. Good brackets though.
21 - 38 of 38 Posts
