1 - 13 of 13 Posts
handlebar, vibration My sprint ST has a buzz in the handlebars that quickly puts the my hands to sleep I got a throttle mister and rocker to help work my hands but it make ridding not very fun:mad: any idea, fixes?
I guess it work like dynomat or a mute in the bell of a trumpet to stop the vibration going through the hollow pipe
I know people that have jammed rolls of pennies into 1" bars. The Bar Snake I guess only works with bars and not clipons I guess?
On mine I have Grip Puppies, that helps.
Sent from my iPhone;)
When I took the weighted bar ends off and put the aluminum ones that came with the hand guards I also picked up a lot of vibration. It may be a choice between hand guards or weighted ends. I also put the gen mar risers on at the same time. I was thinking of sliding a piece of flat rubber between the risers and tree and between the risers and clip ons for vibration dampener.
Just thinking out loud.
2000 Sprint St BTW
Scruff, it's probably not vibration putting your hands to sleep.
You might be putting too much weight on your palms, or you're gripping the handles too tight.
I too have had a buzzing in my handle bars for the last 7k miles with no luck on finding the issue. I have replaced tires, checked fairings and the bar ends. Bike is going to the dealer for an idle issue on Tuesday so I will bug them about it again. The next route for me is to try different bar ends.
There is a slight buzzing in the handlebars of all sprints at times, but most of us just ride around it. Loosen your grip on the bars, hold on with your knees. You will learn to avoid certain RPM's for an extended time. It's part of the character of the sprint, so you feel the engine. If you cannot live with it, you need a Japanese hondakawazuki , with no soul..
This isn't a slight buzz. I have owned thumpers and twin before and have put over 20k miles on my bike in three years with at times over 2k in less than a week. I know to expect some buzzing but when it becomes a nuisance after 45 minutes it is not just a little bit. I have worked on my riding style and tried Gen-mar risers but that is not the issue. The issue is somewhere in the bike. I just have yet to figure out what it is.
1 - 13 of 13 Posts
