1 - 13 of 13 Posts
Can anybody tell me about thread vs. no thread on handle bars
I want to swithch to "M" bars and possible bar end mirrors
Which one should I get ???
If I get threaded will that eliminate any future mirror option ???
I think I am partial to no threaded plugs. The reason: any type of bar end mirror can be fitted, pehaps with a bit of ingenuity. With the plugs that is likely as well, but you may find yourself needing to drill them out or remove the plugs.
Get whatever's cheaper. :)
Threads Vs Plugs
I don't understand
What are the threads for ???
And what do you mean about drilling out the plugs are they permanent or do they screw out ???
The threaded bars have the plugs in them like the stock bars. You can modify a set of regular Napolean mirrors by getting a bolt that matches the plug threads (your end cap screws) and trimming the rubber. It works great I did it for a while with my stock bars. However, if you are thinking about CRG mirrors I don't know that they will fit with the plugged bars.
Hope this helps.
A
So in what way can the threadless bars be capped? I am looking to install only 1 bar and mirror and then cap the other side off. Is this possible?
In fact, it is easily done. Took a 10-32 philips head SS screw and nut. Dug up a large washer that just fit in bar, cut a one inch piece of garden hose. Put screw through cap, put on hose then washer then nut, snugged a bit so nut would hold, slid it in bar and tightened a bit to expand the hose. No problems.
Hell, guess you could glue it on too!
Thanks for the advice! Now off to order the bars and CRG mirror.
just go to a bicycle shop and get some handlebar plugs for 1" bars.
they should have lots to chose from.
Mine are carbon fiber and cost me $.50 each (yeah I know I was swindled)
If they are a little loose then just put some duct tape on the tangs to fit.
Discussion Starter #12
thread vs. non
Well the bars have arrived and guess what they were pluged (threaded)
:confused:
Now that I have them in hand I get it . After hearing all the talk from all --I contacted New Bonnivile via email and asked for the non capped (open end) version but when the came they were capped.:sad:
New bon was hard to reach by phone but had a back in forth dialouge via email
Thought they understood my request but still sent the threaded version. :mad:
Well I guess I'll stick with this style and sounds like I can make it work.
Hope this helps any furture Bar End newbies :rolleyes:
1 - 13 of 13 Posts
