1 - 8 of 8 Posts
Hi,
Ive just replaced my t100 fork springs with hagon progressives. Recommended oil level is 150mm down from the top (with fork compressed and empty of internals) using 20 SAE oil (checked with hagon...these are their recommendations)
Has anyone used this recommended set up.......any thoughts on the resulting ride quality...changes made?
Thanks for any help
Just done exactly the same mod yesterday, plus i also fitted a pair of Hagon icon rear shocks at the same time.
The diffence was outstanding, it now handles like it's on rails, compared to the stock set-up, where the handling was more like riding on marbles.
G ; )
I did exact same on my Scram a while back.
The Hagon springs came complete with a litre of 20W oil.
Set up by the book was fine and, in conjunction with fitting Ikons on the back, it transformed the ride.
I also took the opertunity of fitting pre-load adjusters which greatly aided the set-up.
Simple mod but very effective.............
http://www.triumphrat.net/1132937-post1.html
While your in suspension mode you may want to give it a try!? :)
V.
Thanks Chaps, thats good to hear.
I have Hagon classics (shrouded) on the back so Im looking forward to some decent weather and a chance to give it a try.
Need to think about the next mod now......
:D
What is your weight? Some of us are in better paddocks than others :)
Modesty prevails!
But some would say Im probably on the heavier side of average!! :)
V.
Hi,
Thanks for any help
Did mine with Hagon springs last fall. The only further work I'll do on the forks is add a little more pre-load. It's a very smooth spring. For comparison I usually run racetech's but went for a change.
1 - 8 of 8 Posts
