After a sunday of knee down and ripping off my sliders on my Bonnei SE, ( very scary diving feelings) I have decided that it time to change the fork springs with hagon progressive springs, but I did notice that they do not have a specific part number for the SE model.
Are the Bonneville T100 fork springs compatible with SE 2009 model ?
Thank for help !
The SE springs are 285mm and the T100 springs are 330mm long.
You can use the longer Hagon progressives for the T100 if you wish but you will have to reduce the length of the 235mm long SE tubular spacers.
Or...
if you wish to keep your unsprung weight down and have no objection to continue using linear springs; you could fit a pair from a HONDA,CBR600,1994-1996 model year.
These are 10mm longer than the stock SE springs so the spacers still require a slight reduction in length,
Available in 8.5N and 9N spring weights from K-tech, Derbyshire (and other suppliers) K-tech Part no. 35-295-85 for the 8.5's and 35-295-90 for the 9's.
Current cost £85.01 plus £10.50 postage.
I also noticed Hagon didn't quote a part no. for the SE, so I rang them up prior to ordering. No problem, they sent the correct length springs and the jobs done.
