here's some info on it..
Universal KOSO GP-Style speedometer Type RX1N with black speedo face. Dimensions 152x81x28mm.
Has a very beatiful shape that compliments the lines of the scoot perfectly. The clearly designed instruments are easily to read even under hard acceleration. Here is a short list of the features:
Speed Unit reads km/h or MPH
Reading up to 360 km/h or 223 MPH
Odometer up to 99999,9 km or Miles
Two trip odometers up to 999,9 km or miles
Speed warning in the range from 30 to 180 km/h (20-110 MPH). Adjusting unit in 5 km/h or MPH
Memory of reached Top Speed (0-360 km/h or 0-223 MPH)
Rev Counter up to 15.000 U/min. Unit 100 U/min
Memory of highest revs
Temperature gauge in °C oder °F from 0-120°C or 32-248°F. Unit 0,1°C/F
Temperature gauge with bar chart from 20-120°C (68-248°F). Unit 10°
Digital Oil temperature reading from 0-120°C (32-248°F). Unit 0,1°C/F
Memory function of highest temperature
Fuel gauge with bar chart. 10 bars each 10 fuel level
Works with most common tank sensors. 100 Ohm or 510 Ohm
Free setting of reserve warning between 10-50.
Clock
Acceleration Test 1, how long does it take to pass a given distance. Distance can be defined between 50-1000 m (1/32 - 20/32 Miles). Unit 50 m (1/32 Meile). Perfect to get used to sprint races
Acceleration Test 2, how long does it take to reach a selected speed. Speed selection is possible from 30-360 km/h (20-220 mph)
Top Speed Timer Testing, here you have info about your reached top speed, passed distance and max revs
http://scooter-center.com/catalog/product_info.php?products_id=9394&language=en&PHPSESSID=b905ba23a756f7152d155743577480d3
