I did mine a couple of months ago, best modification I`ve done so far.
Just a couple of observations and opinions
1. There IS a safety benefit but it is only minimal. Tubeless tyres are generally safer because they are less prone to blow outs causing the tyre to come off the rim. On our bikes, if you have a blowout with an inner tube and the tube splits, the air can only escape very slowly through the hole causing the puncture, as the tyre is beaded firmly, the inner tube valve is bolted in place and there is ALREADY tape sealing the spokes. In the event of a puncture at speed the tyre has exactly the same chance of staying on the rim, whether you are running tubes or not. The safety benefit is that deflation is likely to happen more slowly with a tubeless tyre.
2. Some people think that carrying a tube or a patch kit, a pump and a couple of levers is all they need to provide a roadside fix. I`d say that anyone attempting this is going to be in for a rude shock. It`s struggle even at home in the garage without a proper tyre changing rig. I`ve managed this on dirt bikes many times but this is a different hovercraft full of eels. It`s a pig.
3. Others think that carrying a can of gloop will also work. Our bikes come with butyl tubes, butyl tubes don`t bleed air like natural rubber tubs but they tend to split when penetrated, so there is a high probability that gloop won`t work. And if you don`t think it`s safe to do a home tubeless conversion, do you really think it`s safe to ride with gloop holiding your tube together?
4. Lots of people will tell you it is insane/dangerous/stupid, none of them have actually tried, their opinions are based on fear.
5. Lots of people will tell you it works really well, they have ALL tried and their opinions are based on personal experience.
6. If you don`t have a tyre changing rig at home, remove the wheel at home, take it to a motorcycle shop to get the tyre removed, do the conversion then bring it back to have the tyre refitted. As per point 2, it`s a pig.
I also own a Scrambler 1200 XE and a Tiger Explorer, both run tubeless spoked wheels and if I wanted to do any big trips like overnight rides etc, I`d use either of these bikes and I`d only ever use the T120 for shorter rides because of the risk of getting stranded with a puncture and an expensive recovery. Now, I`m happy to do big trips on the T120, or at least I could if I wasn`t in lockdown!
