Hello was just finishing up the wiring on 78 t140e and was thinking if I made up short length of wire that I could connect from possitive on second coil to battery that would enable ignition system only to work to get me home if no not if when electrics play up .
Discussion Starter #2
You tube
Wanted to say I have learnt so much from Lunmad on you tube he's just brill
Just to clarify my bike is 79 year model with Rita electronic ignition and negative earth
It’s called hot wiring Bro, and vital to know about on these old tarts.:wink2: And BTW, you'll hotwire to the power supply of the rita, and not to the coil. Hotwiring to the coil is for points ignition. HTH. RR :).
Hi RR,
Uh-uh, Jonner The OP is talking about his '79 T140E, which is 'negative ground', so the supply to the Rita from battery -ve doesn't have a switch in it; they (kill and ignition switches) are between "possitive on second coil" and battery positive.
Hth.
Hi RR,
Hth.
You’ll remember I don’t rate myself on auto electrics but I could hotwire the old family saloon (negative earth with contact points) with a wire from batt + to the coil +. :laugh2:
With my 72 T120 and a Pazon EI, I have a permanent hotwire installed that bypasses the main iggy switch with a connection from the batt -VE to the Pazon through a fuse. I kill the engine with the kill switch. Works for me. I’ve used it twice (broken iggy wires) quick easy to connect. Back on the road in 2 minutes. RR :smile2:
