Hi, I am unsure of what gear oil to put in my 1970 t100s. Mainly do I need a gl-4 oil, will a gl-5 oil harm it? Also as far as fork oil goes, do I need to get an actual fork oil or will engine oil work, and if it will does it matter if it is single grade or multigrade?
The following are taken from an original factory manual of the period and are correct for the T100S of 1970.
Gearbox SAE 50
Forks
SAE 30 Temp Range (ambient) 60 - 90f
SAE 50 Temp Range 90f+
Both are single grade motor oils.
The fork oil is much thicker than a modern fork oil.
Later the factory started specifying EP90 Gear Oil which is a special "Extreme Pressure" gear oil. This is what I use.
In my 70 T100, I use 80W/90 gear oil (Lucas brand, usually) in my gearbox. GrandPaulZ says 10W/30 in the forks ... I've used 30W fork oil and I've used 30W (straight weight) motor oil. I may try the 10W/30 soon ...
