My tank has surface rust visible inside from the previous owner not storing it properly (my best guess). Has anyone had experience with the KBS coatings kit?
I've never used that one but I have used two others (happens when you buy a lot of old POS's!)
Kreem used on an old /5 Beemer tank. End result was OK but it was a pain to work with and I am not sure it got all the old junk out well. IIRC the instructions were to add rocks or old bolts etc... into the tank with the mixture and shake vigourously!
POR 15 on the other hand used a chemical reaction to etch the inside of a Yamaha XS850 tank and then the coating bonds with that sort of. Better product IMO.
I have POR-15 in my Bonnie`s narrowed tank.GREAT stuff. I have heard equally good reviews with the Caswell stuff,and plan to use it on my fiberglass tank project. STAY AWAY FROM KREEM !! http://www.caswellplating.com/aids/epoxygas.htm
Well, I have used the Kreem on several tanks with good results. It is a 3 part system with an etching agent. You do have to be on top of your game when you use it - but you can get good results.
I'll try one of the other systems next time, since you folks seem to think they are easier...
I have used POR 15 a few times, and provided you follow the instructions and take care with the preparation, it is a permanent fix. The only downside is that it takes a week or so to cure.
A forum community dedicated to Triumph Motorcycle owners and enthusiasts. Come join the discussion about performance, racing, cafe racers, bobbers, riding, modifications, troubleshooting, maintenance, and more!
