I am going to remove my fuel tank, i found a link from a few pages back but i have a question.
On the left and right side of the tank behind the 'cheeks' of the tank (or more discriptively, on the inside of where the 3 tiger stripes are on each side there appears to be a hoses into the fuel tank. These are separate to the fuel pump connectors.
What are these hoses for?
and
How do you remove them so to remove the tank completely? :???:
Hi boocat,
You shouldn't need to remove those hoses to remove the tank, they connect the front of the tank to the rear of the tank and lie outside all frame members; so the tank should just lift off, complete with the hoses.
I think they are probably there just to equalise the fuel between the front and the rear of the tank; the front and back of the tank are lower than the middle, so if you didn't have the pipes there you would end up with a pool of fuel at the front of the tank which you wouldn't be able to use :wink:
t.
[ This message was edited by: tcowjww on 2006-12-02 18:37 ]
tcowjww is right. These pipes are useful if you need to drain the tank (eg to give the fuel gauge sensor a fettling). You do need to make sure you don't trap them when you refit it.
