To get that damned fuel line connector off I usually twist it around a bit vertical, pinch the indents hard with the thumb and finger and wiggle it off. Remember before you get the connector off not to raise the gas tank beyond the height of the supplied support or you may break the fuel pump spigot (that will really make your day).
-When I got the gas tank off I noticed that the wiring harness on the back of the air box was snagged and a wire with a bare spot was showing which I taped up. I noticed that the rear bolt on the fuel pump snagged the harness when lowering the tank. When lowering the tank you need to push up on the harness with your finger until the bolt is past the harness. You also need to push in on the harness on the left side cos sometimes the gas tank catches on it. If the gas tank is not going down smoothly do not force it but check where there is interference; it can save you tracing some wiring shorts. - Wayne
