21 - 26 of 26 Posts
Discussion Starter #21
My money is on the ECU as well. I found the manual and troubleshot the system.
I jumped a fuel injector to ground and instant fuel spray. The manual was a huge help through the process (aka, should have started there). Seems odd that the ECU would fault out, but I'm new to Triumphs and guess anything can happen.
Discussion Starter #23
What would a bad tip over sensor do? I've tried disconnecting as I read it should still run, but just with codes. Everything appears to work as normal, except the injectors not grounding to squirt fuel. That's the last unknown..
21 - 26 of 26 Posts
