Gerry,
Here is the link that leads to Panther's Dens' most excellent index of parts: http://www.triumphrat.net/maintenan...rint-st-aftermarket-part-numbers-2nd-try.html
The Purolator/NAPA/whatever price is around US$6.
The big honkin' gasket is supposed to be re-used. There is no reason not to, unless it is cracked or otherwise non-gasket-like.
The 'screen' is also re-used.
Be very careful when re-making the fuel fittings and the proper routing of the hoses when you set the tank back into position.
