My bike was running a bit off and I just discovered that the air/fuel mixture screw is actually a plug for some EPA reason. I tried to slot the plug but it didn't work. Does anyone know where I can find some real screws at?? Also, how many turns in would be a good place to start once I put the new screws in. Help!
Best
Desperately stalling bonnie black
You must have an earlier model Bonneville in which a thin plug is over the adjustment screw. You need to drill a small hole through the plug, thread in a screw, grab the screw head with pliers or something, and yank it out.
Later models, like my '07, have a D shaped screw which requires a special tool to adjust.
Try the search function for more explicit directions for you job. I know you do not want to go too deep with the drill - like just enough so it goes through the material.
If you do have a later model bike, you're looking at the wrong spot, LOL!
Oh, I think stock set up is 2 and one half out. [Thinking about a shop manual?
Ah I see. I actually have the D shaped screws. where can i find the tool to do the adjustments? I shaved them down a little thinking I could try to use a small screw driver or tweezers, but that didn't work.
So maybe I should just get two new D screws and the tool. Everything for the bike seems to need an extra accessory!
Thanks guys for clearing this up, and any help with the tools (or a standard screw that I can used a good ol fashion flat head on) is greatly appreciated!
newbonneville has the tool - works well, you can make one [I did out of an air nozzle tube, kinda sloppy fit], you can replace with thumbscrews at newbonn as well.
NewBonneville also has replacement thumbscrews that completely eliminate the adjustment tools and working blind, well worth the cost for the reduced aggravation.
