Just converted to tubeless and have a brand new tube that is not needed. It is a Metzler, Rear for a 17" rim. Here's the info from the box:
Part-110-6605
Size - 17" Type B
SKU - 100779
ME-F17M/C (TR4/V1-09-1)
Tire Sizes:
4.50-10
5.10-17
130/70-17
130-80-17
120/80-17
110-90-17
120-90-17
The 150/70-17 is not listed but when I bought it (Motorcycle Super Store) this was the tube listed for the Tiger rear.
$10 plus S+H.
Please PM me.
Thanks,
Doug
What did you use to seal your rims? I've been considering converting to tubeless and with my recent change of employment status now might be a good time to do it.
Discussion Starter · #4 · (Edited)
After wire brushing and cleaning the rim thoroughly with acetone, I applied Flamemaster Chem-Seal CS3204A1/2. Iansoady used a competing product PRC-DeSoto PR1422A1/2 (same MIL spec). I injected the material using a 30mL industrial syringe into the nipples and around them and allowed the material to fully cure. In the next step I touched up any areas I thought lacking, then painted a strip around the rim, placed a rim strip on and finally brushed a coat over the top of it and on the edges of the rim strip.
I only have 500 miles on the conversion; no leaks. So far so good. As always this is not a recommendation for others to perform the conversion, just information. Proceed with caution and at your own risk.
I've been meaning to get around to doing the conversion and now that I'm out of work I have the time. I've got over 70k miles on my Tiger and only changed the tubes once, at about 50k just because I felt guilty. Never have had a flat. What do you want to bet that I pick up a nail within a week if I do the conversion...
